carb issues
Old Jul 20, 2010 | 08:38 PM
fourwheelndaddy's Avatar
Angry carb issues
ok i have another issue with this 01 ds i just baught. i have had issues with gas dripping from the drain on the carb and yes the drain screw is tight. then just today went to start it and it was leaking gas from the exaust only when tried to start it, and i had to use the chock to get it started where before it would start with out the chock. and it would fire almost instantly now it cranks for almost a min. any ideas.
Old Jul 20, 2010 | 11:46 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
You need to take that carb apart and clean it real well. It sounds like it sat for some time and got gummed up. The float is probably sticking open and if you leave the petcock open it will drain the tank.
Old Jul 21, 2010 | 10:41 AM
shaunman1979's Avatar
Exactly what ACE said, the float is sticking or out of adjustment so that line is not only a bowl drain but an overflow so all that gas doesnt just flood your bike out more than it is doing now.
Old Jul 22, 2010 | 06:27 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
The float needle goes into a body that is pressed in and has a o-ring.
Remove the body and get a new o-ring. The thickness diameter is 2mm or .080" thick.
Can't remember the ID, just measure the old o-ring.
They dry up and get hard, and thus start to leak.
OMR
Old Jul 22, 2010 | 07:41 PM
hey cleaned the carb witch was not ditry at all and put new plugs in it and its back to firing up almost instantly without the choke.
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
