have an 87 cyclone need some slight guidence
Old Jul 27, 2010 | 09:42 PM
crowpopper's Avatar
Default have an 87 cyclone need some slight guidence
im new here but just picked up a cyclone 250x today
it wasnt running , gas was pouring out or the carb
so out in a new needle valve and stopped the gushing fuel
adjusted her in a bit and run it i had very littler low throttle responce but mid throttle she hammered then wide open it dogged back down
i think i may need a plug not sure though
also i didnt see any smoke outta the thing
where is the oil injection assy and te adjustment located? i looked at diagrams online and cant find a spot to richen it up
and if i just disconnect the oil injector what is the oil gas ratio to be used?
over all i am 220 lbs and this thing is fast for a 250
i passed my fatherin law on his 300 he was at a steady 40 and i whipped by him
also there is no tube of air filter hooked to the carb is there supposed to be a "u" shaped tube to the air pipe 6 inches above it? i think this may be some power isuues also as its sucking in hot air down there
thanks for any assitance here
~josh
Old Jul 28, 2010 | 11:22 AM
TLC's Avatar
TLC
Make sure the Engine compression is at least 110psi, The Polaris 400 is mixed at 40:1 when people run with not sure of the 250. Did you clean the carb real good when you had it off? Here a good how to on cleaning a carb.Disassembly and Cleaning of a Mikuni Round slide Carburetor
Old Jul 28, 2010 | 08:53 PM
crowpopper's Avatar
the carb was acid dipped prior to me getting it
it is spotless
i got her running pretty good today
the airbox was missing the guy i got it from sold it with a box of stuff for another quad
so i took a rubber radiator hose and a cone filter and installed it and took the hose clamp for the carb inlt and wired it solid to the frame so it didnt wobble
it is a lil bit bogey on wideopen throttle yet but not bad still need to fine tune it
right no its down due to the front tire being bad
it had 3 large plugs in it so i tried to dismount the tire and install a tube but the tire was dry rotted bad and is now shot
i called 4 local places for a tire no one has a 22x8x10 in stock and the cheapest i found was like 59 bucks
i found a pair on ebay for 75 with shipping
i just want a used tire for now until i get the thing working good and can be sure its going to work out
befor i dump any money into it
anyone have any tire around they would get rid of cheap?
Johnny Mac
Aug 15, 2019 03:13 PM
Beeline08
Nov 11, 2016 04:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
2many2ride
Sep 27, 2015 04:35 AM
merryman
Sep 19, 2015 03:15 AM
