06 kodiak 450 4x4 problems
Old Aug 9, 2010 | 09:47 PM
scruffdog's Avatar
Default 06 kodiak 450 4x4 problems
it started when you pushed the 4x4 button the 4x worked fine, when you pushed the diff lock button, the diff light on the dash would flash and not engauge, no noise from the relay. so i started to check it with my test light, when i touched one of the wires the system made that engauging noise and blew the 4x4 fuse. now as soon as you turn the key it blows the 4x4 fuse,anyone??
Old Aug 12, 2010 | 11:46 AM
CraZySteve's Avatar
Sounds like the actuator motor is siezed up... why don't you shoot me an email and I will send you the Service Manual in 3-4 emails (too big to send in 1 email)
snowwmax@yahoo.com
-Steve
Old Sep 19, 2010 | 12:09 PM
scruffdog's Avatar
i got the 4x4 to work again, the only problem now is when i push the diff lock button just the light for the diff lock on the dash flashes, no relay, servo noise, nothin. i still have 4x just no locker
Old Sep 19, 2010 | 12:37 PM
CraZySteve's Avatar
Ok - I have the Service Manual.... send me an email snowwmax@yahoo.com
-Steve
Old Feb 12, 2011 | 05:21 PM
biggrizzbigboy's Avatar
Did you ever find the problem with your quad? I did the same thing today and have been trying everything to fix the prolblem
Old Apr 5, 2011 | 02:55 PM
Default Its FIXED!!!!!
Got everything to work again. I think the servo was just in a bind. I pulled the front servo off. Made sure the button was in 2wd. Re-attached the wires. Push the button into 4wd, and then engaged the locker. I then disengaged everything back to 2wd. That centered all the servos. Unplugged the wires, installed motor, plugged in wires and re-filled front diff. Works like i never had a problem. Just thought i would share the fix in case someone has the same issue.
lightninboy
May 16, 2021 09:52 PM
RedRancher
Oct 15, 2020 01:45 PM
txpedsrt1
Feb 3, 2017 08:07 PM
Desimation2k8
Jul 17, 2015 12:37 AM
RedRancher
Jul 10, 2015 06:36 PM
