At the end of my rope and need help.
Old Aug 12, 2010 | 08:21 PM
dawgsfan's Avatar
Default At the end of my rope and need help.
So I got a polaris explorer and it had a fuel leak (stunk up the whole garage). Took it to the local shop and paid to have the carb cleaned. They cleaned the carb changed the oil and supposedly got it in top shape. Took it home and gave it a ride. It bogged down easily and the next morning found that it still leaked fuel (a nice puddle on the garage floor). Called them and they said bring it on back. So I did. They said it was a part in the carb that was worn and they changed it out. Picked it up today. Got it home and it started bogging down from the start (could hardly get it out of the truck bed). Got about a half mile from home and it flat out quit on me. I could crank it only if I held down the throttle. It would allow no idle at all. So now it sits in the back of my truck (my buddy helped me push it on) ready to go back to Cycleworks for a third time. I'm actually scared to take it to them. It's gotten worse each time I've gotten it back. Your advice as to how to approach the matter with them would be helpful. I don't want to be the jerk but I want it done right.
Old Aug 12, 2010 | 11:04 PM
FunRide's Avatar
Dawg....Did you verify the fuel filter was not clogged? Might be an issue with ethanol fuel if it's an older machine. Ethanol can eat the guts from older equipment. Might need to rebuild the carb with a kit from Polaris.
Old Aug 13, 2010 | 07:51 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is it a fuel line leaking or maybe the flaot is sticking not shutting off the gas and flooding it? how does it run in netural, free reving or bogs out as before. oh and assuming your bike is a 2 stroke xplorer, there is no oil to change in the engine, so what did they change? is this a 3 or 400 ?
Old Aug 15, 2010 | 07:42 AM
dawgsfan's Avatar
Well I called first thing Friday and made a fuss. They took it back in and called me to pick it up later that day. They said it was a "pinched" oil line?? going into the carb. They also replaced the spark plug (which they had replaced the first time). I took it out to the land yeasterday and it ran solid. HOWEVER, on first crank it acts choked down and takes a second to get into a steady idle. Once there it's fine. Also, before I took it in after riding it for say 4 or 5 min. and shut down the fan would come on. I ran it half the day yeasterday and no fan??? Called them and they said it would have to reach a certan temp for the fan to work. Odd to me.
Old Aug 15, 2010 | 10:04 AM
TLC's Avatar
TLC
Yes the fan comes on only when it needs to,if the red high temp light and no coolant is boiling over your fine.
What kind of Xplorer is it? 4 stroke or the 400 2 stroke.
Old Aug 15, 2010 | 01:38 PM
dawgsfan's Avatar
300 two stroke. A friend said it could be running cooler now that the carb is cleaned and it's getting a better supply of oil mix to the engine.???
Old Aug 16, 2010 | 01:26 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i don't beleave thats even a liquid cooled bike and the fan is to help the oil cooler i think?
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Sassinm1
Sep 30, 2015 04:23 AM
Matt123
Sep 29, 2015 01:29 AM
