2001sports man 500ho starter
Old Aug 14, 2010 | 03:30 PM
stcspiderman's Avatar
Default 2001sports man 500ho starter
I have a 01 sportsman 500ho, starter went bad I pulled the plastic belt cover off looks like the pulley need to come off?
I was wondering how do they come off. do i need a special tool or not.
Old Aug 14, 2010 | 10:39 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
you can get away with using a piece of 3/4" fine all thread with a couple of nuts on the end to pop the primary off. The secondary should just slide off once you remove the bolt. On a side note: Your clutch's look pretty dirty from the pic. Make sure you clean them up good and inspect them before you put it all back together. And did you remove the bolt from the primary? If not there should be one there.
Old Aug 15, 2010 | 08:41 AM
Kerbbirds's Avatar
The starter is on the top of motor, connect to the other side , not on the side pictured
Old Aug 15, 2010 | 09:46 AM
TLC's Avatar
TLC
You take the starter out from the top by removing the air box under the seat, Thats how I did mine,100X faster and easier. The botom starter bolt will disconnect but not pull out.you just turn the starter,untill the bottom bolt is on top and pull out the whole starter. My Clymer Manual also said to remove the pullies and back plate but you don,t need to. Put the cover back on.
Turn out to be just a sticking bush when I took the starter apart, I cleaned and freed it up and its been working great for 3 years now.
Old Aug 15, 2010 | 11:08 PM
79hugger's Avatar
Yep it will come out as mentioned without removing the clutch
Old Aug 16, 2010 | 01:12 PM
it works thank dam i wish i ask before i pulled everything else apart
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
