06 rancher es
Old Sep 16, 2010 | 09:14 PM
Hondarick's Avatar
Default 06 rancher es
Hi i have an 06 rancher es.Back in April I blew the bearings in the swing arm and busted the rear shock so the only thing holding the rear end on was the shaft and a tow strap we tied around the swing arm.when i got it home it sat for about a month and a half before i got around to fixing it,so when i got everything back together i started the machine with the pull start because the batt was completely drained. today i finally got the new rear shock after being backordered for 5 months put it on tried to start and nothing i jumped the battery and it turned over while jumping but would not fire ,i was getting code three on the display which is the angle sensor code,than a few minutes ago we got a strong smell of gas it the house went down stairs and gas was pissing out the overflow tube, so my question is would a dead battery be giving that code and the carb be blocked so the fuel is dumping out or is everything that is happening unrelated
Old Sep 17, 2010 | 02:08 PM
papahouse's Avatar
Charge the battery if it will hold a charge or get a new one and clean the carb. Most likely the float has gummed up and is sticking causing the gas to over flow the bowl.
Old Sep 17, 2010 | 08:17 PM
Hondarick's Avatar
the battery does not hold a charge so im going to pick up a new oneand that is what i was thinking as far as the carb. Thanks for the help
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
