96 trail boss transmission help
Old Oct 6, 2010 | 09:48 PM
dustinward03's Avatar
Default 96 trail boss transmission help
I recently picked up a 96 trail boss with a broken shift linkage. Fixed the shift linkage. Heres the problem. When I put it into forward and hit the throttle it immediatly pops out of gear and makes a grinding or rattling noise. I even tried removing the shift linkage and putting it in forward then starting it, makes no difference. It goes in reverse no problem. I did check the fluid and it needs changed for sure, but would that be enough to make it pop out of gear like that? Should I be looking for a new tranny? All help greatly appreciated.
Old Oct 7, 2010 | 01:49 AM
mrtwostroke's Avatar
well eliminating the shifter linkage, tells me that it could problems with the enagement dogs wore out.
Old Oct 7, 2010 | 12:36 PM
MECHANIKE's Avatar
there is a needle bearing,$25 that went out in mine, replaced it,,,,,,, done,,,,,,,,,,,,
Old Oct 7, 2010 | 03:25 PM
Overdrive's Avatar
Pull it out and take it apart. The problem will be obvious. Replace the chain while you are in there.
After you get it done fill the trans with Castrol Syntec 5w50. Change it at least once a year and you will have no more problems.
Old Oct 7, 2010 | 07:10 PM
anyone have a good walk through on removing the transmission? Or a manual I can download
Shainasmash
May 8, 2017 06:38 PM
cornermike
Aug 10, 2016 06:47 AM
Backwoods_badass
Aug 2, 2015 10:40 PM
Backwoods_badass
Aug 1, 2015 10:25 PM
Gnuters
Jul 19, 2015 10:03 AM
