08 500 sportsman gear oil?????
Old Oct 11, 2010 | 04:37 PM
scooter123's Avatar
Default 08 500 sportsman gear oil?????
So I went to change the front and rear gear oil and I used quaker 75/90 synthetic gear oil.....will this type of oil be ok????? Or will it harm the ATV
Old Oct 11, 2010 | 05:42 PM
Overdrive's Avatar
HUGE mistake. Drain both ends now.
Use the special Polaris fluid in the front and Castrol Syntec 5w50 oil in the rear.
You may have to change the front a couple of times now. ALL traces of the 90 weight must be removed from the front so the 4wd will work correctly.
Old Oct 11, 2010 | 06:56 PM
TLC's Avatar
TLC
The front diff uses AWD Hillary fluid and the back uses tranny fluid. I use sthythetic chain case oil for the tranny. 90 Weight gear goes in neither.
Only Polaris with the locking hubs 2003 and down, use gear oil in the front diff.
Old Oct 11, 2010 | 08:02 PM
scooter123's Avatar
my bad...glad I didn't drive it!!! I guess its off to the polaris dealer I go this week!!!
Old Oct 11, 2010 | 09:04 PM
TLC's Avatar
TLC
There is no separate rear diff on the SP500, its more like a tranny/rear diff, all in one combo. Thats why the rear takes no gear oil.
Old Oct 12, 2010 | 10:23 AM
Overdrive's Avatar
If you don't have access to the correct Polaris fluid for the front 5w20 synthetic motor oil will work for a while with no damage to anything.
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
coolguy420
Jul 10, 2015 01:17 AM
sara durrant
Jul 6, 2015 05:32 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
