How do you remove top plastic on handlebars to get to headlight?
I need to get to my headlight to replace the bulb, but not sure where to start as far as how to take the plastic off that contains the speedo and headlight....thanks
There should be 5 screws total...the 3 you pulled already and there are 2 more on the bottom side towards the front of the pod. The easiest way I found to get at the bottom 2....crank the bars as far to the right as you can go and use a shorty phillips to get the bottom left out. Crank all the way to the left...same. The entire top piece should then lift right off...you might have to unplug the speedo to give yourself enough space to get at the back side of the light so you can remove the bulb.
Good luck!
Wenty
gorylewis
27
Oct 4, 2015 05:22 PM
