How do you remove top plastic on handlebars to get to headlight?
Old Oct 29, 2010 | 04:13 AM
xplorer400rookie's Avatar
Default How do you remove top plastic on handlebars to get to headlight?
I need to get to my headlight to replace the bulb, but not sure where to start as far as how to take the plastic off that contains the speedo and headlight....thanks
Old Oct 29, 2010 | 07:15 AM
lovmudd's Avatar
Not sure what year or model you have but, most newer models have three screws you have to remove, One on each side and one on the back, then you can lift off the top to get at the bulb.
Old Oct 29, 2010 | 01:35 PM
Sorry I have a 95 Xplorer...I took 3 screws out that face driver... and still no luck!...seems like there are more screws hidden or clips???
Old Oct 30, 2010 | 06:25 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
looking at the parts breakdown it looks like there is only screws holding it together, so maybe gentaly pry or push on the plastic hosuing to seperate
Old Oct 30, 2010 | 04:05 PM
Bowana's Avatar
The click together in addition to the 3 screws so just pry them gently and something will let go and then you can get the top off and open the pod to access the light.
Old Oct 30, 2010 | 09:07 PM
Thanks Bowana....I will try that!
Old Oct 31, 2010 | 08:21 PM
Wenty's Avatar
I'm fairly certain nothing "clicks" together. DO NOT pry them apart...well, unless you want to break something!! The tabs on the headlight pods break very easily if your not careful.
There should be 5 screws total...the 3 you pulled already and there are 2 more on the bottom side towards the front of the pod. The easiest way I found to get at the bottom 2....crank the bars as far to the right as you can go and use a shorty phillips to get the bottom left out. Crank all the way to the left...same. The entire top piece should then lift right off...you might have to unplug the speedo to give yourself enough space to get at the back side of the light so you can remove the bulb.
Good luck!
Wenty
gorylewis
27
Oct 4, 2015 05:22 PM
toonces
Aug 5, 2015 05:55 PM
chris7420
Jul 30, 2015 02:04 PM
kodiak450.
Utility ATVs
13
Jul 27, 2015 05:07 PM
Captjay
Jul 23, 2015 12:33 PM
