Banshee clutch
Old Dec 10, 2010 | 03:15 PM
jraz's Avatar
Default Banshee clutch
I just bought a banshee, but super familiar with blasters. I am replacing the clutch and wondering the exact order of plates and friction disks. Curious if I need 7 cushion rings? I believe my blasters only had one. This clymer book isn't real clear.
Old Dec 10, 2010 | 07:38 PM
sand addict's Avatar
you dont need the cushion rings,the clutch will work better without them and will last longer,make sure you soak the frictions in oil before you install them this will insure proper break in and prevent chatter.start with a friction end with a friction,make sure you set the adjustment on the clutch arm with the indicator on the case,and always make sure you have free play at the lever.
Old Dec 10, 2010 | 08:01 PM
jraz's Avatar
Right, Everything worked without them. Seems my cable is stretched, not much adjustment/play. I was wondering why someone would choose a br8es, over a b8es plug?
Old Dec 10, 2010 | 08:41 PM
banshee's need a resister plug to cut down on ignition noise,at high rpm's ignition noise or frequency from two strokes can cause a misfire,also run your gap at .028.....
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
