Tranny and rear diff fluid change
Old Dec 17, 2010 | 06:56 PM
Plumberjim's Avatar
Default Tranny and rear diff fluid change
I am going to replace the tranny fluid and rear diff fluid on my 2000 Sportsman 500. The manual states there is a drain plug for the rear diff??? I can't find it. I also cannot find the fill hole. I found the drain for the tranny. After doing a search, It appears that the tranny and rear diff are all one unit and that they fill and drain togther through the tranny. Is this right???
Thanks,
Jim
Old Dec 18, 2010 | 01:34 PM
la90043's Avatar
Is it not chain driven?
Old Dec 19, 2010 | 08:24 AM
Kerbbirds's Avatar
Thats correct, tranny and rear diff are in the same case on the 500, book says to use the demand drive fluid, I use the same oil that I put in the engine which is 5-30 Castrol Syntec, the fill plug is on the otyer side of case drain on right fill on left if I remember
Old Dec 20, 2010 | 12:40 AM
Overdrive's Avatar
You would be better off with the 5w50 Castrol Syntec in the trans.
Bratman2
Aug 6, 2022 01:42 AM
robert301972robert
Aug 30, 2015 11:34 AM
NatePerz
Jul 27, 2015 03:27 AM
Sandman2.0
Jul 21, 2015 09:03 AM
rcappie4
Jul 10, 2015 04:54 PM
