2003 polaris 90 bogging????
have a polaris 90 atv.... it starts off carb cleaner but kills itself almost immediately and wouldnt rev at all. so i took the carb off figuring its the carb that needs cleaning and found it spotless. i left the carb off abd sprayed carb cleaner directly down the intake without that carb on because that should make it take off.... it bogged just as much as when i had the carb on. it refuses to rev up.... i need to have this running today.... help?
Is there a rubber boot between the carb and the motor?
It may be sucking air in there(cracked/loose) instead of taking the fuel in directly from the carb......Caper.........
2003, 90, 90cc, atf, atv, bogging, carberator, carbourtor, carburetor, pic, picture, polaris, problems, rev, wont
