2003 polaris 90 bogging????
Old Dec 22, 2010 | 10:00 AM
invisible4good's Avatar
Default 2003 polaris 90 bogging????
have a polaris 90 atv.... it starts off carb cleaner but kills itself almost immediately and wouldnt rev at all. so i took the carb off figuring its the carb that needs cleaning and found it spotless. i left the carb off abd sprayed carb cleaner directly down the intake without that carb on because that should make it take off.... it bogged just as much as when i had the carb on. it refuses to rev up.... i need to have this running today.... help?
Old Dec 22, 2010 | 02:29 PM
200x_Basket's Avatar
change the plug
Old Dec 22, 2010 | 02:31 PM
alright. it has good spark but the plug is pretty nasty...
Old Dec 23, 2010 | 07:20 AM
Kerbbirds's Avatar
did you take the carb apart and clean out all jets and passages? how old is the gas?try new plug
Old Dec 23, 2010 | 08:48 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Is there a rubber boot between the carb and the motor?
It may be sucking air in there(cracked/loose) instead of taking the fuel in directly from the carb......Caper.........
Jmuddin284
Jan 19, 2026 07:16 AM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
