2001 trailboss wont start, fuel issue, fuel pump?
Old Jan 10, 2011 | 03:17 PM
Judd's Avatar
Default 2001 trailboss wont start, fuel issue, fuel pump?
Cant get my trailboss to start, it has been sitting around for a while.
Removed the spark plug and it seemed real dry
I removed the fuel line from the carb and there does not seem to be any fuel coming out when I crank it
Tried fuel switch in ON and RESERVE.
Found an inline fuel filter near the pump. I can blow through it both ways. If I blow real hard, it wont allow air though. cleaned it the best I could. i didnt have the right nozzle to put on the air compressor
Put it back in in the same direction it was in before (machine ran for over a year before this) but the way I was tracing the hoses, it seemed in backwards. tried both ways
Then I found the fuel pump. I disconnected the hose going back to the engine and when I cranked, there was air pressure.
I disconnected both of the other hoses, one at a time and no fuel came out.
All i can think is the pump is broken
I was going to take the pump apart but decided to hold off
Am I on the right track or am I way off base?
help?
Sucks, its snowing, schools,work etc is closed and everyone is out on 4 wheelers
Old Jan 10, 2011 | 04:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the filter should have an arrow on it for the direction of the flow. is gas getting down to the fuel pump form the tank? the pump should have a vacuum line coming form the engine to make it work. you could cheat and dump a little gas in the spark plug hole to start the bike w/ everything hooked up right and it might be enough to self prime the fuel pum again. just an idea.
Old Jan 10, 2011 | 05:21 PM
Judd's Avatar
If I remember right, the fuel goes to the selection **** (ON, RES), then one line goes to the pump, then to the carb.
I forget now but I think the filter was on the line from the selection **** to the pump, but the arrow was facing towards the ****. Didnt make sense to me as the fuel should be flowing from the **** to the pump
I can take another look tomorrow
I tried starter fluid and couldn't get it going. That's when I decided to start looking at the fuel system
Does the line from the engine create a vacuum or apply pressure? will it suck fuel from the tank? or does it pressurize the fuel to the carb?
njrider64
Jul 4, 2017 01:40 AM
BEEFKING69
Jun 17, 2015 12:38 AM
Big600twin
14
Jun 16, 2015 09:30 AM
Jbird4681
Jun 9, 2015 01:59 AM
1000gade
May 27, 2015 12:37 PM
