Removing heated grips
Old Jan 16, 2011 | 11:45 AM
Rowe's Avatar
Default Removing heated grips
I need to replace the kill switch controls on my 800. It quit working so I took it apart to check out if the contacts needed cleaned up and found the contacts are melted into the switch. I tried to fix it and put it all back together but it would only work when you pushed in on the switch. I ended up just ordering a complete housing and switches new but I will have to remove my grip to take the old one off and the new one on. Has anyone tried getting them off successfully without messing them up? I have the Hot Grips by Symtec. I havent looked yet but do they sell just the grips as replacements without having to buy the controller and everything else. Hopefully so I can save a few bucks. Thanks for the help fellars!
Old Jan 16, 2011 | 02:51 PM
IQSLEDNECK's Avatar
I was able to buy just the heat elements and I think it set me back $15 american dollars. And MAN DID THEY WORK BETTER!!! I was suprised at how much warmer they were and how much faster they warmed up
Old Jan 16, 2011 | 02:57 PM
RAM IT's Avatar
This might help you out.Replacement "No Adhesive" Left Grip for 210029 or 210050
Old Jan 17, 2011 | 05:52 PM
Rowe's Avatar
Thanks! From what I've read you just have to cut them off. I got one ordered from the link provided from you Ram It. Thanks for all your help guys!
Old Jan 18, 2011 | 09:29 AM
switzomatic's Avatar
You can spray some wd-40 in them and they should slide off.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
PrairieDog126
Sep 12, 2015 06:53 PM
awer1968
Sep 8, 2015 11:02 AM
black_thunder
Sep 7, 2015 01:24 AM
antiguogrumete
Sep 5, 2015 03:41 AM
