Transmission chain problems
Old Jan 27, 2011 | 11:47 PM
kx250nut's Avatar
Angry Transmission chain problems
I have a 2001 Polaris 500 scrambler 2x4 it appears the transmission chain has stretched and it is so long it rides so high on the gear it slips teeth. Is that what normally wears out in the transmission. I see signs the chain has slightly rubbed the case, but all the gears look like there’re in good shape shift fork, and forward and reverse gear and bearings all are in good shape. Are there any specifications on the chain length? Or has anyone had similar issues? Thanks
Old Jan 28, 2011 | 05:50 AM
ftwflh's Avatar
From my experiences I just change out the chain if I have to split the cases
Old Jan 28, 2011 | 08:06 AM
kx250nut's Avatar
I am replacing it, just was curious. Thanks
Old Jan 29, 2011 | 07:15 PM
kx250nut's Avatar
I replaced it and it works Great so if you hear a quick chatter, and it hardly pull itself it might very well be the chain like mine.
Old Jan 30, 2011 | 08:13 AM
Kerbbirds's Avatar
They usually start slipping in revese before they do forward
Old Jan 30, 2011 | 10:21 AM
ramman67's Avatar
Default trans
That transmission is gear to gear in reverse.The trans silent chain is only for forward gear only.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
bikedad3
Jul 2, 2015 02:15 AM
