another awd problem
Old Feb 20, 2011 | 09:36 AM
refg3880's Avatar
Default another awd problem
we all no that the front coil needs 12 volts to work. but does it? my 04 700 awd works but takes me a few wacks of the throttle for it to engage.
when i check the battery it reads 11.2. bike starts fine but after about 5-6 mins of running the battery light comes on and the needle flashes.
the question is if the voltage is down could the awd not work till the rpm come up and the voltage comes up over 12?
also my override button acts funny....... works fine the awd light comes on when pushed and the speedo says slow, but i i dont push it i still have full power in reverse. the awd wont work unless pushed like it should, but why in 2wd do i have full power?
Old Feb 20, 2011 | 11:31 AM
Kerbbirds's Avatar
If battery is weak it will cause problems, is it c, harging, does volage come up to 13.5 or more at battery when you rev it up?A good battery will show over 12 volts when shut off
Old Feb 20, 2011 | 12:35 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
th battery should be 12.4+ voltsif it's a good battery off and running it will push 13.5+-volts. i would say charge the battery 100% and then try to see if the issue is still there to pin point if thats the cause. imo
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
