2002 Polaris Sportsman 700 Twin. 3 headlight MOD
Old Mar 5, 2011 | 08:07 AM
bjones12's Avatar
Default 2002 Polaris Sportsman 700 Twin. 3 headlight MOD
I have a 2002 700 Sportsman, and I am trying to hook all 3 lights to run at once. I ordered the cheap relay/hookup off of ebay, and every since my battery light has been flashing. Is there something that I've done wrong? I checked all of my wires and nothing is grounding. Will the 02 stater push that kind of power? Any help would be great
Old Mar 7, 2011 | 01:02 PM
Big600twin's Avatar
Battery light flashing usually means that you are in a state of discharge on the battery. I know mine will sometimes come on if I am running lights, winch and hand warmers at the same time. I had the 3 light conversion on my rig and it didn't flash. I wonder if the "cheap" relay is the issue??
Old Mar 7, 2011 | 03:36 PM
switzomatic's Avatar
How old is the battery? If it is getting weak that could be your problem. Any battery store will check it for free. If that's not it then check voltage while running-no lights, running-normal lights, and running-all 3 lights. If there is a lot of variation then you probably either have a problem with the mod or stator going bad(worst case). Running all 3 should not drain that much if you are driving because the rpm's will help keep a good charge.
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
coolguy420
Jul 10, 2015 01:17 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
