1987 Bayou 185 Wiring Diagram
Old Mar 20, 2011 | 08:25 PM
vintagecast's Avatar
Default 1987 Bayou 185 Wiring Diagram
Fine Folks
As many people before me, I need a full wiring diagram of an 87 Bayou 185. I'm new and just learning about atv's (as proof - trying to make a non running 87 bayou come back to life) Help out a dumb person. Thanks
Old Mar 21, 2011 | 09:37 AM
Hayashi's Avatar
I have a '88 220 wiring diagram which might be similar to 185.
What kind of specific electrical issue(s) are you having with the 185?
Old Mar 21, 2011 | 09:14 PM
Default 1987 bayou wiring
Hey Thanks for the reply.
Well dumb people chopped up the harness and tried to bypass the Nuetral switch. But.... I have no fire, replaced the coil and still have no fire. I suspect the CDI but I cant rule out other things because the wiring is junk.
I have seen the 88 250 wiring and it has 5 wires to the CDI and mine has 7. It looks like the wiring from 85 - 87 would be about right. Thanks for the response and the bump.
Somebody please help me out there are several people before me that have been looking for this. Help the bumb newbee out.
thanks
Old Mar 22, 2011 | 08:37 PM
Default 87 Bayou 185 wiring
Fine Folks
Maybe I can figure out what I need without the wiring diagram. The are a pair of wires (Red and Black)that come from the cdi to the motor. Anyone tell me what this is? There are 7 total wires from the cdi. Green goes to the coil. yellow/red and black/yellow are kill switch. and then blue and Black/white to pick up on motor.
any help?? thanks
Old Mar 23, 2011 | 09:51 AM
Hayashi's Avatar
Red wire goes to the stator coil.
Black wire goes to the pickup coil.
Old Mar 24, 2011 | 09:01 PM
Default 87 Bayou 185 CDI/ wiring
anyone have a 1985 - 87 185 cdi????
Old Mar 25, 2011 | 09:38 AM
Hayashi's Avatar
You may want to look for a 220 cdi since it has 7 wire connection also, just like 185 does.
Old Mar 27, 2011 | 08:29 PM
Default 1987 Bayou wiring
Anybody have a 1987 220 wiring diagram??
Old Apr 2, 2012 | 07:48 PM
leewrisley's Avatar
I could be wrong, but the CDI is the little black box mounted near the wheel with the magnet pickup. It should only have 2 wires coming off it, the stator next to this location also has 2 wires. Are you looking at the harness behind the battery the voltage regulator? I wouldnt mess with the CDI if you have wiring issues elsewhere first.
I can take a picture of my wiring for you if you like, or you could tell me which wires are cut and ill tell you where to reconnect. Let me know if I can help out.
Atvnewb88
Aug 19, 2015 02:22 AM
Atvnewb88
Aug 13, 2015 06:48 AM
Tadej Dylan Vuzem
Jul 27, 2015 07:26 AM
Chocobamofo
Jul 10, 2015 07:46 PM
tweeder
Jul 5, 2015 01:57 PM
