Need Help, chasing running issue on my 250
Old Apr 12, 2011 | 09:09 AM
tex599's Avatar
Default Need Help, chasing running issue on my 250
I have a 2004 AC 250. Bike will start and run fine when cold, after it warms up, it will die when giving gas. Carb is good, my stator or magneto is showing .9-1.1 ohm on the 3 yellow wires, spec should be .66 the trigger coil ohm are within spec. Quick question, will a bad stator cause running issues?
Old Apr 12, 2011 | 09:29 AM
suzukiman1983's Avatar
In more cases yes stator-wire-ignition coil once warm no spark depending on the issue
Old Apr 12, 2011 | 10:38 AM
tex599's Avatar
Thanks, I could understand no spark at all when warm. But it will idle all day long even when warm. It only dies as if are giving it gas at after warming up.
Old Apr 12, 2011 | 07:23 PM
07 400's Avatar
Did you try a new spark plug
chinkapin
Jul 14, 2016 06:58 AM
BEEFKING69
Jun 17, 2015 12:38 AM
robj
Jun 15, 2015 08:45 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
Steven Bandemer
May 27, 2015 07:39 PM
