Radiator Hose/Engine Block Location Xplorer 400
I just did a rebuild on my 99 Xplorer 400 engine. I didn't mark where the hoses go from the radiator to the engine block. There are two possible combinations. I have a manual and couldn't find anything. Anybody know? Thanks.
As you are facing front of radiator,LEFT hose on radiator goes to water pump inlet at bottom of engine, RIGHT hose goes to top of head.(hoses are already pre formed,should be easy to tell) ALWAYS when coolant is installed,bleed small 10 mm screw at back of head (close to rear sensor) to remove any air bubbles,open screw just enough for coolant to flow out until straight coolant comes out OR can overheat and blow the new head gasket! OPT
Trying to get everything that I can out before senility hits me! OPT
well you do a fine job keepin us ,..kickin up mudd!!
jrooker6
Apr 23, 2016 07:36 PM
