Radiator Hose/Engine Block Location Xplorer 400
As you are facing front of radiator,LEFT hose on radiator goes to water pump inlet at bottom of engine, RIGHT hose goes to top of head.(hoses are already pre formed,should be easy to tell) ALWAYS when coolant is installed,bleed small 10 mm screw at back of head (close to rear sensor) to remove any air bubbles,open screw just enough for coolant to flow out until straight coolant comes out OR can overheat and blow the new head gasket! OPT
jrooker6
04-23-2016 07:36 PM
