07 polaris hawkeye
Old Jun 17, 2011 | 07:37 PM
riding dirt1965's Avatar
Default 07 polaris hawkeye
How difficult is the engine clutch chamge over do I have to remove the transmission form the engine to get the cover off then replace the engine clutch never did this before or is there a shortcut thanks Billy
Old Jun 17, 2011 | 11:27 PM
Welcome the the forum!! NOT quite under standing exactly what you want to do?? If you are trying to get to the clutches,you have to pull the big metal clutch cover off. PLEASE explain what you are trying to do so we can be of help?? OPT
Old Jun 18, 2011 | 08:40 PM
Default 07 pol hawkeye engine clutch
I ahve tore down the whole rear-end but cant get the little yoke off the front driveshaft to remove the trans so I can replace the engine clutch behind the primary clutch belt drive
Old Jun 18, 2011 | 09:20 PM
If you are talking about the "prop shaft" (shaft from the transmission to the front gear case), at the front of the yoke is a "roll pin" or spring pin as its called that has to be driven out,then the shaft can be pushed Back off the gear case towards the transmission Then if you have to,slide the prop shaft forward to remove from the transmission,IF this is the shaft you are describing! To re install slide on the tranny end first then pull forward and line up hole on yoke with hole in front gear case shaft and re install pin OR a new one if old pin is too damaged! If you are talking about the FRONT drive shafts,they just pull out from the front gear case! P.S. May take a little force,a hammer and a DULL chisel to persuade the prop shaft to move rearward on the transmission splines! OPT
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Sportsman850
Jul 31, 2015 04:25 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
