07 polaris hawkeye
If you are talking about the "prop shaft" (shaft from the transmission to the front gear case), at the front of the yoke is a "roll pin" or spring pin as its called that has to be driven out,then the shaft can be pushed Back off the gear case towards the transmission Then if you have to,slide the prop shaft forward to remove from the transmission,IF this is the shaft you are describing! To re install slide on the tranny end first then pull forward and line up hole on yoke with hole in front gear case shaft and re install pin OR a new one if old pin is too damaged! If you are talking about the FRONT drive shafts,they just pull out from the front gear case! P.S. May take a little force,a hammer and a DULL chisel to persuade the prop shaft to move rearward on the transmission splines! OPT
