Belt light goes off, but switch is not flipped
Old Jun 18, 2011 | 12:27 AM
IHScoutII's Avatar
Default Belt light goes off, but switch is not flipped
I am having a problem with a Prairie 700, the belt light will flash, but the switch inside the cover is not flipped. It did this a few weeks ago, reset the light and today the same thing happens. I reset the light and about a minute or two same thing happens. Each time the switch has not been flipped. The belt is new, adjusted on the tight side and I have no idea what is going on. Can anyone help??
Old Jun 20, 2011 | 01:53 PM
Hayashi's Avatar
The micro toggle switch at the belt cover is going bad. So even though it's not physically tripped, it becomes open momentarily and triggers the system to flash belt light. You need a new switch.
Old Jun 20, 2011 | 10:04 PM
panaboy's Avatar
Hi guys I have a trouble with a Kawasaki KFX 700, it has a belt light blinking and when I running it star backfire, somebody know whats is a trouble?
Old Jun 21, 2011 | 07:57 AM
bruteforce65006's Avatar
Ya need to reset your belt light. Its the routine check, spose to come on ever 100 hours. Im not sure were the reset plugs are on a KFX, you can go here and make a thread to find out if you cant find it. But it should have a grey plug and black plug on it somewhere, probably under the seat, and just rotate them, unplug the wire that's on top off the belt, and turn the key on for about 30-40 secs watch the light flash fast then it should slow down, turn the key back off and return the plugs to the original spot. should stop the light and limp mode.
Kawasaki ATV Forum
Old Jun 22, 2011 | 11:25 AM
Hayashi's Avatar
That's not true.
Flashing belt light and engine going into limp home mode is not a routine check. That means there is a CVT belt trouble, like too much slack in the belt.
Steady belt light means the routine 100-hr check on the belt and CVT system.
skinnyr6
Aug 25, 2023 02:18 AM
ScopeZ_
Jul 28, 2015 01:44 AM
jayking232003
Jul 23, 2015 05:48 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
