major help needed d s 650 no spark
Old Jul 7, 2011 | 09:51 PM
jeepsluvmud's Avatar
Default major help needed d s 650 no spark
It all started when I jump started my d s 650 with a car battery. It ran great till I disconnected the the.cables. the second I took the cables off.the quad shut off and will not start again. I'm getting zero spark and I have checked the fuses and replaced the spark plugs. I have no idea what it could be. Please help!!
Old Jul 9, 2011 | 07:29 AM
Hightower's Avatar
it is not possible for the DS to run with a bad battery.
it will stay running if it has a good battery that is just too low to crank the starter motor, but if the battery is no good meaning bad cell then it is not possible for the DS to run.
Old Jul 9, 2011 | 07:42 PM
Default thanks for the reply I'll try that asap
But the battery will crank the ds with no problem. Could the battery still be it
Old Jul 10, 2011 | 06:46 AM
Hightower's Avatar
oh I see, no if the battery is cranking the motor its okay,
if no spark and you already changed plugs and checked connections at coils and such then you may have a fried CDI box, its on the front left side of the frame, you can see the bottom half of it sticking out from under the tank cover. ideally you would have access to a buddy's to swap it real quick and see if that's it before buying a new one.
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
TegraQuad
13
Nov 26, 2017 01:40 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
