425 Magnum four wheel drive issue
Old Sep 7, 2011 | 02:40 PM
dabeast's Avatar
Default 425 Magnum four wheel drive issue
Hello to all fellow Polaris people! I couldn't find my old profile so I made another one, its been a little while since I have posted on here.
Ok, we have a Polaris 425 Magnum that runs strong when it runs and still looks great after many years of hard work. When you push the 4 wheel drive button, it works for a little while until you encounter some deep snow or something that requires more power. It seems like the front right axle doesn't want to go, throws the chain off by the right foot plate and knocks the 4 wheel drive out. Not a good thing when you're plowing snow
I'm guessing its the front right axle but could be wrong. Noticed when you back the machine up in 4 wheel drive sometimes it turns hard to one side.
Any ideas?
Thanks!
Old Sep 7, 2011 | 04:14 PM
Probably need to adjust the center chain plus check the middle eccentric housing for bearing wear especially if the center chain keeps jumping off! Plus when the center chain is adjusted it affects the front chain slack. If you haven't serviced the hub fluid in a while,might be time to check em out! Plus sounds like an armature plate is sticking in the hub( Replace both plates as the other side almost always starts sticking a little later!) OPT
Old Sep 7, 2011 | 05:41 PM
dabeast's Avatar
I will try that! Thanks! Do you think thats whats causing the chain to jump or is it the axle? I dont want to dump too much money into it just because its used as a work horse, nothing else.
Thanks
Old Sep 7, 2011 | 05:54 PM
Either way too much chain slack and needs adjustment,a worn chain(you can flex chain from side to side ) plus check the bearings on the center tightener. All of these can affect the chain jumping off! OPT
D-Hagz
Jul 4, 2015 02:19 AM
volsgo30
Jun 4, 2015 06:07 PM
Steven Bandemer
May 27, 2015 07:39 PM
CanadianViking
Feb 16, 2001 11:56 AM
caldwell
Oct 28, 1999 03:30 PM
