98 Polaris xplorer 400 belt deflection problem
Old Sep 7, 2011 | 11:56 AM
68charger440's Avatar
Default 98 Polaris xplorer 400 belt deflection problem
Hello,
I have a 98 xplorer 400 that has a loose belt. I removed all but one shim in the driven clutch but I still can pinch the belt together between the two clutches until they touch. It is a brand new polaris belt. The belt is a bit longer by an inch than my book says it should be, but I got it from a polaris dealer. Is that a common problem with belts not being the exact length? Also, should the belt rest all the way down on the drive clutch when its not running? Any ideas?
Old Sep 7, 2011 | 02:58 PM
First off is it a # 3211077 belt? If so and you have removed two shims from inside the driven clutch,I'd check the engine motor mounts,plus CENTER to CENTER on the drive clutch bolt and driven clutch bolt should be 10 inches! The belt should rest all the way down on the drive clutch and towards the top on the driven clutch,belt deflection measured from the top middle should be less than 1 1/2 inches! Hope this gives you a start. OPT
Old Sep 7, 2011 | 04:42 PM
Yes it is a 3211077 belt. Center bolt to center bolt is 10 1/8". The belt's outer circumference measures 41 3/4 " but my book says it should be 40.875. Is it common for them to be off by that much? That seems like it could be a problem being off from the book by nearly an inch, or is my book wrong. Clymer in not the best at accuracy sometimes. Thanks for the help!
Old Sep 7, 2011 | 05:49 PM
Best thing I can tell you is to check it out against another belt if everything else checks out ok on the clutches,,etc! With two shims out of the rear clutch you shouldn't be able to collapse the belt! OPT
Old Sep 7, 2011 | 06:05 PM
Ok... Will do. Thanks again for the advice!
TJM
Jun 11, 2015 01:28 PM
kencbs
May 23, 2015 05:29 PM
patriot96
Oct 8, 2002 01:22 PM
rsoxfan
May 30, 2000 12:23 AM
rsoxfan
May 28, 2000 03:27 AM
