Clutch belts
Old Sep 14, 2011 | 12:33 PM
NHOJ_28500's Avatar
Default Clutch belts
On my 2000 Sportsman 500 I have a problem with my clutch. I go through two belts a year. When I put a new belt on it runs top notch. But as soon as I put it under a load such as heavy mudding or plowing snow I start losing performance. In about six moths or so I check the belt and it way below tolerance for width. What is my problem?
Thank you
Old Sep 14, 2011 | 02:00 PM
First question: Do you use low range under loads or when driving under approx 7mph?? This seemed to be the major cause on a lot of belt issues I had. Getting too hot if left in high range and glazing the belt! Only takes once or twice then the belt will further degrade. Plus clutch alignment,creeping etc,can be a factor. OPT
Old Sep 15, 2011 | 08:01 PM
NHOJ_28500's Avatar
Yes i do always run low range under load or slow riding. And the last time it was checked the clutch was properly aligned.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
