Phoneix problems
Old Sep 14, 2011 | 10:44 PM
AkSteve's Avatar
Default Phoneix problems
We bought a used 2005 Phoenix and it has no low end torque. We replaced the CDI unit with one that is supposed to allow another 1,000 rpm's, replaced the regulator/rectifier with a better one. Moved the little tab in the ignition back and put in a new spark plug. It still won't take off like it should. Once it gets rpm's built up it goes plenty fast. Is this a fuel issue or a clutch issue? It seems to take off faster in reverse. Were stumped and my Grand Son is bummed!
Old Sep 14, 2011 | 11:50 PM
HMT Racing's Avatar
Have you changed rear tire size? If not I would suspect the clutches
Old Sep 15, 2011 | 12:26 AM
AkSteve's Avatar
Default No changes
Thanks for the reply. The tires are stock. We can have the clutches looked at. Are there clutches that can be bad that would allow the engine to get rpm's faster in reverse then in forward?
Old Sep 15, 2011 | 07:28 PM
Med30's Avatar
Hi, try changing the rollers back to stock (Polaris part number 0452471) on the drive clutch, I bet they were changed previuosly.
Good luck.
Old Sep 15, 2011 | 11:43 PM
AkSteve's Avatar
Default rollers?
I will look into that, even though I don't know what it is. I am determined to get the machine running better for my Grandson. He is a natural born gear head! Thanks for the reply.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
