06 polares sportsman 450
it has been some time i have been on......good to see you all. question, whith the polaris running, if i disconnect the battery, it dies, should it? i have a brand new ecm in it, part #2203348. thank you
DON'T disconnect a battery while running! It can not only blow out bulbs,but can cause damage to sensitive electrical components along with the new ecm you installed!! This ignition isn't like the old "magneto triggered" only system of years past to where they could be cranked with a dead battery!And even that system manuals warns about disconnecting a battery on a running machine! OPT
check the voltage while it is running to see if it is even charging. it should be at least 13.5 or better. as others have mentioned these newer bikes can destroy the eletronics w/ it running and no battery.
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
cdstang
Aug 31, 2015 07:52 AM
OPT
