06 polares sportsman 450
Old Sep 30, 2011 | 02:56 PM
coffeeman14213's Avatar
Default 06 polares sportsman 450
it has been some time i have been on......good to see you all. question, whith the polaris running, if i disconnect the battery, it dies, should it? i have a brand new ecm in it, part #2203348. thank you
Old Sep 30, 2011 | 03:50 PM
user493's Avatar
Moto Psycho
You shouldn't disconnect the battery with it running because it can blow all the light bulbs. But IMO that shouldn't stop it from running.
Old Sep 30, 2011 | 04:38 PM
DON'T disconnect a battery while running! It can not only blow out bulbs,but can cause damage to sensitive electrical components along with the new ecm you installed!! This ignition isn't like the old "magneto triggered" only system of years past to where they could be cranked with a dead battery!And even that system manuals warns about disconnecting a battery on a running machine! OPT
Old Sep 30, 2011 | 05:02 PM
so, what can be the problem now? thanks
Old Sep 30, 2011 | 06:06 PM
What was the reason for disconnecting the battery in the first place while it was running?? OPT
Old Sep 30, 2011 | 06:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check the voltage while it is running to see if it is even charging. it should be at least 13.5 or better. as others have mentioned these newer bikes can destroy the eletronics w/ it running and no battery.
Old Sep 30, 2011 | 06:23 PM
to see if it still runs with the new ecm, but it didn't. the only thing the new ecm corrected was the fan, which wouldn't start at all, now it does.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
