2004 Polaris Sportsman 600 - need help!
Old Oct 8, 2011 | 07:36 PM
darilynn's Avatar
Default 2004 Polaris Sportsman 600 - need help!
We have a '04 Polaris Sportsman 600 and it is overheating and reading "hot" on the display. Our cooling fan won't come on. I am new to Polaris bikes and am not sure what to try...we don't have a manual and any information or ideas would GREATLY be appreciated!
Old Oct 8, 2011 | 07:49 PM
Welcome to the forum! I'm almost deaf,but not blind yet,can read you perfectly! Most of the time its # 4010161 thermal sensor in the radiator that shorts out and not allowing the fan to cycle on and overheats.If the fan is NOT coming on when it over heats,you can try 12 volts direct to the fan motor to see if its ok. If fan works I would suspect the radiator sensor.Also trapped air in the system can cause problems(Always if adding coolant leave the cap off until fan cycles on,this purges any trapped air) Also radiator caps can be faulty and allow coolant to spew out. PLUS battery must be fully charged to allow 12 volts for everything to work right! Hope this is enough for you to trouble shoot! OPT
Old Oct 8, 2011 | 09:43 PM
darilynn's Avatar
Thanks! I appreciate it - will give those a try.
Old Oct 9, 2011 | 03:03 PM
ofie's Avatar
Had same issue, I buried it in the mud and the cable going to sensor was damaged. You can hot wire the fan to make sure its not the fan. Take off wire connector going to snsor and jump it and turn the key on. The fan will go on.
Old Oct 9, 2011 | 03:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. also make sure your radaitor is 100% clean back and front.
Old Oct 9, 2011 | 11:28 PM
darilynn's Avatar
Thanks gonna give these a try.
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
jettman
Jul 6, 2015 12:16 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
