Need help with 85 tri-z
Yeah definately clean the carb, just take the carb loose and turn it sideways enough to get the bottom bowl off (4 screws). Then take the brass jets out and make sure you can see thru them, then clean the bowl and you should be all set.
The jets are clean. Bowl is clean. I'm wondering about the fuel pump. How much fuel should come out of the hose when you kick it? It only seems to trickle, is that normal? I'm not used to bikes with fuel pumps.
the fuel pump should squirt gas out about 2 feet. sounds like you are going to need to rebuild your fuel pump. If you keep use the starting fluid you will need to rebuild your motor. Starting fluid burns hot and dry that motor needs oil.
Dan
Dan
If I remember right, 120 is good. I think it could be as low as 90 and as high as 150. Should get there on at least the 2nd kick.
CRamshaw777
Jul 18, 2015 05:46 PM
