Need help with 85 tri-z
Old Nov 23, 2011 | 07:20 PM
Jtp77's Avatar
Default Need help with 85 tri-z
I just got an 85 tri- z. It can only get it to run with starting fluid. It is getting gas but will not stay running any suggestions on what I should do?
Old Nov 24, 2011 | 07:03 AM
woodsidewarrior's Avatar
It sounds like it has a dirty carb take the carb off and disassemble it and clean everything jets passages inside outside everything
Old Nov 24, 2011 | 10:10 PM
Raptor450's Avatar
Yeah definately clean the carb, just take the carb loose and turn it sideways enough to get the bottom bowl off (4 screws). Then take the brass jets out and make sure you can see thru them, then clean the bowl and you should be all set.
Old Nov 25, 2011 | 07:45 PM
Jtp77's Avatar
The jets are clean. Bowl is clean. I'm wondering about the fuel pump. How much fuel should come out of the hose when you kick it? It only seems to trickle, is that normal? I'm not used to bikes with fuel pumps.
Old Nov 26, 2011 | 08:13 PM
fishing star's Avatar
the fuel pump should squirt gas out about 2 feet. sounds like you are going to need to rebuild your fuel pump. If you keep use the starting fluid you will need to rebuild your motor. Starting fluid burns hot and dry that motor needs oil.
Dan
Old Dec 17, 2011 | 06:46 PM
Jtp77's Avatar
Can someone tell me what the compression should be on a two stroke 1985 yamaha 250? And how many kicks to reach that compression?thanks
Old Dec 19, 2011 | 08:23 PM
Raptor450's Avatar
If I remember right, 120 is good. I think it could be as low as 90 and as high as 150. Should get there on at least the 2nd kick.
Old Dec 19, 2011 | 10:20 PM
Jtp77's Avatar
Thanks Raptor450! I took off top end and taking it to the shop. Had 60 on the first kick. Hopefully that's the problem. Has fuel has spark but won't run.
CRamshaw777
Jul 18, 2015 05:46 PM
thebutelr
ATC 3-Wheelers
15
Dec 30, 2006 03:46 AM
Michiganredneck
ATC 3-Wheelers
Oct 28, 2003 09:01 PM
Michiganredneck
Oct 17, 2003 08:52 AM
okie
Mar 16, 2003 10:33 AM
