front toolbox removal 07 sportsman 500 efi
Old Dec 8, 2011 | 01:19 PM
Eric24's Avatar
Default front toolbox removal 07 sportsman 500 efi
I found the easy 4 bolts and removed and the torx head screws underneath and removed but still the toolbox won't separate from the fenders... I am pretty certain I am missing something simple but can't seem to find the next step for removal... could it be you need to just pry the box up and out of the fender connectors??? Just don't want to break things as it is cold outside and stuff breaks easy... Trying to get at the ECU for the ADC ground wire removal,to disable the ADC as it is worn out due to constant use when plowing snow the last few years... Thank you...
Old Dec 8, 2011 | 01:33 PM
Eric24's Avatar
found them... been covered with mud down in the holes of the box on top and hard to dig out frozen dirt to get at them...
Old Dec 8, 2011 | 07:02 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i had to hunt for mine once too for the same reason.
Old Dec 8, 2011 | 07:12 PM
Spdecat's Avatar
I usually pick the dirt loose with a small center punch then vacuum out the dirt with my shop vac . Don't over tighten when you put them back in just snug them up . It would suck to strip one .
neilbedwell
Nov 10, 2018 11:02 AM
VRRRRT
Jun 27, 2015 09:38 AM
yellowpolaris
Jun 21, 2015 11:13 AM
UPLou
Jun 7, 2015 09:42 AM
blaze_master
May 26, 2015 11:18 AM
