front toolbox removal 07 sportsman 500 efi
I found the easy 4 bolts and removed and the torx head screws underneath and removed but still the toolbox won't separate from the fenders... I am pretty certain I am missing something simple but can't seem to find the next step for removal... could it be you need to just pry the box up and out of the fender connectors??? Just don't want to break things as it is cold outside and stuff breaks easy... Trying to get at the ECU for the ADC ground wire removal,to disable the ADC as it is worn out due to constant use when plowing snow the last few years... Thank you...
UPLou
Jun 7, 2015 09:42 AM
