Porting, valve jobs and polishing
Old Mar 16, 2001 | 10:08 AM
ERICsRAPTOR's Avatar
Can there be a difference in porting,can you port for low end or top end, or does it just do the same thing(let air in easier). Can somebody explain to me what each of these do and are they worth it?
Old Mar 16, 2001 | 10:56 AM
AdrenalinFreak's Avatar
I am assuming that you are talking about on your raptor. The answer in short is this. The effects of porting are done through the cam Porting a 2 stroke is the same as changing the lobes of a cam. What you mean by valve job, I am not sure. However, The angle of the valve seat does affect performance, and can be designed for top end or low end performance. Polishing your intake will cause smoother flow, Which is not always desired. Not sure if you would want to do it to the raptor. The same basics apply as what applies to a car. If you look through some hot rod mags you will undoubtably start coming up with your own ideas as to what you can do with your motor.
Old Mar 16, 2001 | 11:16 AM
Have you done this is it worth it or are they blowing up their figures
I was looking at :
http://www.powersportsmall.com/psp/s...D=159&CATID=25
Thanks Adrenaline
Old Mar 16, 2001 | 01:14 PM
PaRoostR's Avatar
As lots of people I do not like trinity and would not suggest them (but it is your engine and your choice not any someone else's). You should try giving TC a call he should be able to explane every thing you need.
Old Mar 17, 2001 | 12:08 PM
I actually ride a banshee, Never owned a 4 stroke bike or ATV, So I cannot give you a idea of what the power gains would be. They seem to be claiming a little high for what is being done, Although a good cam will definatly boost your HP a noticable amount. I am a little confused as to why they would call it porting though, Unless I am missing something that they put in an ATV head and not a automobile engine. If they actually know what they are talking about they should have said a cam, not porting, as just about anyone can tell you that porting is nothing more than changing your intake and exhaust timeing, just like changing your cam.
Old Mar 18, 2001 | 10:27 PM
CaptNemo's Avatar
On your Raptor the improvement percentages sound a bit high, but it would depend on how bad of shape the stock ports are.
If they're welding in more material to change port contours, they can make significant airflow gains, but it's expensive and the heads tend to be fragile.
On a two stroke, porting can change port timing which is equivalent to changing camshaft timing, in addition to enlarging passages for increased airflow.
The gains on a two stroke can be massive if done correctly.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
