CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
04 DS 650 with problems
Old Dec 15, 2011 | 01:44 PM
Stiffler04's Avatar
Default 04 DS 650 with problems
Well I just bought the quad the other day and got it cheap cause it didn't run. Guy said it didn't have spark. And it doesn't.. One thing I noticed is that it will only spin over if the kill switch is in the off position. Also wen it spins over with both the plugs installed it makes a bad screaching noise. It has to be the motor internals or starter but with one plug out it doesn't make a noise. I did a compression test and it had 90 psi. One more thing. Wat is the correct way to check oil in these? Just like a car or does it need to run for a few seconds and then check? Thank's very much guys for any help at all.
Old Dec 17, 2011 | 06:19 AM
bartmann's Avatar
Banned
first thing I would do is pull the flywheel and confirm there is no damage there. 2nd thing I would try is to drain and contain the oil . this might give clues to a problem. also on the bottom of the oil tank under the headlight is a nipple that holds the hose onto the tank,remove it and see how the screen looks. hopefully its something easy to fix.... the guys on this fourm are ds guys and can get you up and going if you keep them posted...
Old Dec 21, 2011 | 02:03 PM
Stiffler04's Avatar
Thanks for the info bartmann. I will try what you said and report back asap. Haven't been able to mess with it yet cause I been too busy with work.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
