front hub oil change
Old Jan 4, 2012 | 01:15 PM
Neptugian's Avatar
Default front hub oil change
Sorry to re invent the wheel, but....
I have a 1996 polaris sportsman. I need to change the front hub oil myself. I cannot find the how to on this, and which oil to use.
Fill how full??
Thank you in advance.
BB
Old Jan 4, 2012 | 04:30 PM
Use Polaris Demand Drive Plus hub fluid. remove the 3/16" allen plug,drain the old fluid at 6 o'clock,fill at 12 o'clock position,turn to 3 or 4 o'clock position to drain the excess out. A little extra won't hurt. The manual says every 50 hrs. If you use it on a daily basis a little more often is better. Check for any seal seepage around the hub and brake rotor along with the rear of the strut housing. OPT
Old Jan 4, 2012 | 04:39 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
demand oil is what it takes and i filled mine w/ a small funnel and w/ out letting air out as the fluid goes in it burbs thw fluid every wear while filling.just have a smal funnel of sorts and take your time to get it inthe small hole lol.
Old Jan 10, 2012 | 07:49 PM
cjb400's Avatar
In a Polaris shop manual I have it lists ATF type F as a replacement fluid. I have always used that without problems. I bought a set of plastic dispensing bottles from Harbor Freight that work great for putting the fluid in.
Old Jan 10, 2012 | 08:14 PM
Clymer Or Haynes manuals along with some outdated shop manuals still list Type F transmission fluid that was replace by Demand Drive hub fluid around the early 90's! You can use it and swear by it,but Demand Drive is actually thinner and from years of using both I'd drive a little further to get the hub fluid and use Type F in a pinch only! Just my old opinion again! PLUS welcome to the forum OPT
rcappie4
Jul 18, 2015 07:51 AM
JackTheKing
Jul 14, 2015 09:09 PM
tporath
Jul 11, 2015 12:31 PM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
