2000 Polaris Expedition 4wd problems
Old Jan 31, 2012 | 01:28 PM
Hspencer's Avatar
Default 2000 Polaris Expedition 4wd problems
hello, i have a 2000 Polaris Expedition and when the 4wd is engaged the right front will not engage. Anyone have any suggestions? Thanks!
Old Jan 31, 2012 | 01:37 PM
Welcome to the forum! First off change the fluid in the hubs and see if it helps. Best to use Polaris Demand Drive Fluid! Jack the machine up and see if both front wheels turn in awd position. If only one does,you can check under the front panel to make sure the connector to the hub hasn't come loose ( two connectors with grey and brown wires leading to each hub) If there is 12 volts going to the hub that doesn't work(grey wire is hot wire,brown is ground) then you may have to pull the hub apart and check the armature plate, hilliard assembly,bearings and strut coil. A lot of times this happens is when hubs are run dry or strut or hub seals are leaking. OPT
Old Jan 31, 2012 | 01:41 PM
Hspencer's Avatar
Default Thank you
Thanks for the Info!!!! i have already purchased the correct fluid so i will change it out this evening. I will also take the steps you have outlined should that not work.
green giant
Jul 13, 2017 12:07 PM
polaris scrambler00
Jun 20, 2015 08:49 AM
wbfjim
Jun 8, 2015 06:20 PM
Peeps
Mar 24, 2000 12:27 AM
blackmagic
Feb 26, 2000 09:27 AM
