CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
Bombadier ds650x Carb
Old Feb 21, 2012 | 04:21 AM
Lesotho's Avatar
Default Bombadier ds650x Carb
Hi Guys
How do i adjust the float on a bombadier ds650x for the fuel to stop leaking from the bottom or if thats the cause of the fuel leakage, i just recently cleaned my carb but since then it cant stop leaking, any idea on how to fix that?
Old Feb 22, 2012 | 01:49 PM
justme23005's Avatar
Its probably the needle & seat... Its very common for them to go bad..
Old Feb 23, 2012 | 07:39 AM
Oldsman67330's Avatar
There is also an O ring on the brass seat that can be bad.
Old Feb 23, 2012 | 11:59 AM
PapaWheelie's Avatar
Is it leaking from around the gasket of the bowl, from the tubes that come off of the side of the carb, or the very bottom of the bowl? Each has a different reason why it might leak.
If it's the bottom of the bowl, that is the drain for the bowl. The screw for the drain is either corroded, or not tight enough. I plugged mine up with a short piece of rubber hose that has a nail in it to completely seal it up.
Old Feb 23, 2012 | 01:55 PM
bartmann's Avatar
Banned
papawheelie ..
yes thats the drain but its also the over flow... when the fuel gets to high from a bad needle and seat issue ... plugging it is a very bad idea ... it has nothing to do with the screw not being tight.
Old Feb 23, 2012 | 06:07 PM
Originally Posted by bartmann
papawheelie ..
maybe the carbs on the 2000 were different? When I pulled the carb apart, I do not see how the drain at the bottom could also act as an overflow.
Old Feb 24, 2012 | 07:51 AM
bartmann's Avatar
Banned
nope there the same 99% of carbs are this way ...
there is two holes for fuel to flow out ,but both holes drain out the same nipple on the bottom. one controled by the drain screw and the other open port is down that brass tube. when fuel goes to high from a stuck or leaky float it will go over the brass tube and out the bottom nipple..... never plug that tube. the fuel will then go directly into the motor and lock it up or fill the oil full of fuel ... bad deal .....
Old Feb 27, 2012 | 12:47 PM
Thanks for correcting me bartmann.
Oh man, I am an idiot! I can't believe I did not figure that out when taking the bowl off. For all the times I read posts where people just spew incorrect knowledge and I get upset, I rally hate joining that group...
I know it's differrent for every person, but it appears my brain started to fade at age 41. It's all downhill from here....
Old Feb 27, 2012 | 02:50 PM
bartmann's Avatar
Banned
We all can learn something everyday ... today was your day ! I'm betting you will pass that on soon to someone in need.. goodluck ...
Old Feb 28, 2012 | 07:17 AM
I worked on a Polaris for a guy once who had plugged the overflow hose with silicone because it was leaking gas....it filled his crankcase to the point the engine would not crank.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
Jul 8, 2015 02:16 PM
