2002 polaris sportsman 500HO running rough
Old Jul 17, 2012 | 07:39 PM
Joopy Peans's Avatar
Default 2002 polaris sportsman 500HO running rough
I have a 2002 polaris sportsman 500 HO that will idle ok for a while but when I push the throttle it runs really rough then dies. It does backfire out pf the exhaust. Also every few pulls with the pull start it will tip the cord out of my hand before a full extension. Anyone have any ideas of what this could be? I was thinking compression maybe. I thought timing as well but I've read a few articles that say the timing is pretty much self adjusted and could only be messed up if it was messed with.
Old Jul 17, 2012 | 07:41 PM
Sorry. Im new to this. Any help would be MUCH appreciated. Thanks.
Old Jul 17, 2012 | 07:52 PM
Welcome to the forum! Could be that the carb needs to be cleaned up (needle and seat replaced,jets cleaned,etc) new plug if you haven't already replaced it, plus you might check the valve adjustment if you haven't done so in a while, .006 intake and exhaust. OPT
Old Jul 17, 2012 | 08:18 PM
Thanks for the welcome. Yeah I cleaned the carb but I didn't replace the needle or seat. I have put a new plug in it though. What would cause the pull start to snap out of my hand like that? It never happened until it started acting up on me.
Old Jul 17, 2012 | 08:26 PM
The 500 has always been bad on ripping the rope out of your hands if you're not careful! I've had brand new ones do this.That's why I always used two hands. Just check the valve clearance and if it still runs rough you may have to go back into the carb to replace the needle and seat,plus if the float arm is wobbly and worn best to replace it and the float arm pin. Most people don't replace this critical part. OPT
Old Jul 17, 2012 | 08:32 PM
Awesome. Ill give her a whirl and see what happens. Thanks a bunch.
whitty
67
Feb 24, 2021 02:52 PM
skittero
35
Mar 1, 2019 12:39 AM
DOAinNY
Jun 11, 2015 10:34 PM
Dakosk
Jun 6, 2015 05:37 PM
May 27, 2015 11:15 AM
