Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
Kasea 90 Skyhawk problem. Any help is great!
Old Sep 4, 2012 | 02:29 PM
kukamer's Avatar
Default Kasea 90 Skyhawk problem. Any help is great!
I just picked up two Kasea 90's 01,02. The 02 runs great. The other does not. It came with the plug out, when I put a new spark plug in it, it would not kick with the kick starter (wouldn't move at all). With plug out it kicks freely. Not a ton of experience with engines so is that a "tell tale" sign that something is horribly wrong? Or is there some hope? I am in the beginning stages of trying to get it running. Was told there was carb issues, I havent touched that yet.
Any idea, help is greatly appreciated!
Old Sep 4, 2012 | 04:37 PM
Jaster94's Avatar
valves could be out of adjustment and locking it down(compression lock). may spin over to TDC and check out the clearances. just a thought.
Old Sep 5, 2012 | 11:37 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Does a bunch of mist/fluid spit out the plug hole when you kick it over w/o the plug in?
Hmmmm, same exact spark plug that's in the running machine?
I'm thinking that this is a 2 stroke. Correct?
Old Sep 5, 2012 | 02:10 PM
kukamer's Avatar
Thanks for your replies. Yes fluid does spit out when the plug is out. Same plug that is in the other atv. And yes, it is a 2 stroke.
Old Sep 5, 2012 | 04:08 PM
LT80's Avatar
LT80 Expert
It's hydraulic locking. Fuel is flowing into the bottom end and when you try to turn it over w/the plug in, it fills the cylinder w/fuel which won't compress.
Clean the carb paying special attention to the float needle/seat area.
Old Sep 5, 2012 | 08:11 PM
kukamer's Avatar
Will do! Thanks so much for your help, I appreciate it!
Old Sep 5, 2012 | 10:26 PM
LT80's Avatar
LT80 Expert
Your welcome.
I should add::
You'll have to spin the motor over w/o the plug in to get as much fuel out as possible. Cover the plug hole with a rag and make sure the plug wire is no where near the plug hole..*spark*boom* lol A night drying out may be helpfull.
Oh yea, the pipe may need to be emptied of fuel.
After that, Install the plug and give it full throttle till it starts and cleans out.
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
papahouse
Jul 28, 2015 12:42 PM
Captjay
Jul 23, 2015 12:33 PM
ghost3
Jul 19, 2015 08:46 PM
