2004 Sportsman MV7, RPM Issue
Old Sep 25, 2012 | 10:51 PM
GH1971's Avatar
Default 2004 Sportsman MV7, RPM Issue
The RPM gauge reads 0 at idle, as you hit the throttle then RPM's will show. Once you release the throttle, RPM's will got back to 0
Old Sep 26, 2012 | 03:18 AM
Check the main harness going into the speedo for any bare wires and the connector itself for any wires not fully pushed into the pins. If all traces out ok the problem could be in the speedo head itself. OPT
Old Sep 28, 2012 | 10:56 PM
GH1971's Avatar
Re-verified fault this morning, now RPM's don't work at all, even when throttle is used. Checked wiring harness, cleaned and inspected all pins, all good. Put a new speedo in and still no RPM's
Old Sep 29, 2012 | 07:36 AM
Receives it's rpm signal electronically. You either still have a short somewhere or the fault could be in the stator wiring. Check the yellow and yellow/red wires from the stator that also go to the regulator/rectifier. I believe on the older mv7 it's rpm signal came from the yellow/red which branched into the speedo harness. The newer model efi 700s also receive the rpm signal from the stator yellow/red wire. OPT
Old Sep 29, 2012 | 10:05 PM
GH1971's Avatar
Well, that explains it, already determined the Stator was bad, already on order, when it comes in will see if that fixes it, thanks OPT
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
jettman
Jul 6, 2015 12:16 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Shifts
Jul 3, 2015 07:59 AM
