2002 yamaha bear tracker 250
Old Oct 17, 2012 | 09:40 AM
sburcham's Avatar
Default 2002 yamaha bear tracker 250
my bear tracker leaks gas out of the overflow hose after running. It leaks even with the gas shut off, it will leak a whole tank of gas out. I also would like to know how to adjust the idle speed. ATV will not idle. Hard to start, but runs well.
Old Oct 17, 2012 | 10:33 AM
Raptor450's Avatar
Looks like you have 2 problems: 1 - Your gas shutoff doesn't work 2 - Your floats in the carb are set too high, the float needle/seat are worn out, or the float needle/seat have trash stuck in it. You'll have to pull the bowl off the bottom of the carb to check it out.
Ean
Dec 19, 2022 08:48 AM
Peter_
Jul 18, 2015 07:06 AM
coolguy420
Jul 10, 2015 01:17 AM
cSchwartz
Jul 9, 2015 02:43 PM
MNatv89
Jul 7, 2015 11:36 AM
