modified stock a-arms
Old Mar 22, 2001 | 08:27 PM
ezwheeler's Avatar
i have seen and read a lot about the overly quick steering and dartiness of the ds.timmyboy seems to have found the fix with there a-arms.since i am short on cash i modified my stock arms.i increased the positive caster 2 deg which is the same as timmyboy.i have not tried it out yet but will let anyone know if they are interested.
Old Mar 22, 2001 | 08:44 PM
Quicksand's Avatar
How about a how you did it post?
Old Mar 23, 2001 | 10:10 PM
ezwheeler's Avatar
remove top a-arms and bushings.you need to machine .065" off the back edge of the pivots.i figured this to be 2-2.5 degrees additional positive caster.you will need to get .065" shims,i used some fender washers,just have to go through a lot of them to find 4 the same thickness.drill out the holes in the shims or washers just big enough for the inner bushing to fit through the shim.need to remove .065" from the 1 plastic bushing per pivot.assemble and grease.mine are a perfect fit and seem just as sturdy as stock.it will cost almost nothing if you have or have a friend with a mill.
Old Mar 23, 2001 | 10:20 PM
ezwheeler's Avatar
i forgot to add that you will need to put the radius back in on the back side of the pivot after it is machined so the plastic bushing will fit properly.i just used a large reamer.
Old Mar 27, 2001 | 12:56 AM
fourlix's Avatar
Way to go EZ-Wheeler!!! Now.. How does it Handle?????????
Silly Later,,,,Fourlix
Pehter
Oct 3, 2024 11:00 PM
dannytas
Sep 26, 2017 06:31 PM
Honski250r
Sep 26, 2015 09:40 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
CosmoM
Sep 21, 2015 04:57 PM
