indicater lamps
Old Nov 21, 2012 | 06:08 PM
papathud's Avatar
Default indicater lamps
hey people happy thanksgiving,to all,now i just attained a 425 magnum 4x4,think its a 99 "gotta check the vin ;but anyway its a 98 or 99 im fairly certain,i need to id the indicater lamps on the dash ,sittin on the machine the third from the left is high beam but other than that ive got nothing lit for reverse or whatever theyre could be there and i dont have a manual for it yet. im sure thered be one for engine temp and reverse maybe? or nuetral but theyres no id or legend there just bare lamps .any help would be greatly appreciated. it runs fine ,works fine,its a great atv,
Old Nov 22, 2012 | 08:45 AM
#4030042 bulbs were common to burn out on the displays. You just lightly take a razor blade on the corner of the indicator plate,pry up,and pull out exposing the bulbs. The bulbs you can get an any auto store. If you need a new indicator plate you get it here. You also have a reverse,neutral and hot indicator bulb along with the high beam.
Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse OPT
Old Nov 22, 2012 | 04:13 PM
papathud's Avatar
bulbs i got..lol the legend plate that identify,s the lamp is gone ...
Old Nov 22, 2012 | 04:15 PM
papathud's Avatar
until i get a new plate i was curious which lamp was temp reverse nuetral etc
of course the high beam is working
Old Nov 22, 2012 | 05:41 PM
user493's Avatar
Moto Psycho
If the bulbs are working you can find neutral and reverse. The high temp light would be whatever is left.
Old Nov 22, 2012 | 06:12 PM
papathud's Avatar
Default lamps
ok here it is bulbs are good i have no indication in nutral or reverse so was wondering which lamp was sposed to be lit in nuetral or reverse,got a manual coming so ill have a schematic and ill go from there . was just doin a quik check here as to get the layout of the dash.the lense was gone when i aquired the atv and high beam was the only thing that i had. no big deal
Old Nov 22, 2012 | 08:54 PM
user493's Avatar
Moto Psycho
Sorry. I thought the bulbs were working.
Old Nov 23, 2012 | 10:25 AM
Just look at the wiring behind the bulb holder. Viewed from left to right(sitting on the atv)
All indicator positions share a common brown(with jumpers).Far left bulb position is the HOT light indicator(blue/white wire and brown) next bulb position is NEUTRAL (Green/white and brown wire) next position is High Beam indicator (Yellow and brown) far right bulb is the REVERSE indicator( purple and brown wire) OPT
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Schneider
Jul 24, 2015 05:05 PM
jayking232003
Jul 23, 2015 05:48 PM
ranvette
Jul 4, 2015 06:13 PM
