Replacing swing arm bushings
Old Mar 22, 2001 | 10:53 PM
Scrambler96's Avatar
I have to replace the swing arm bushings on my son's 92 350 trailboss 4x4. Does anyone know if the complete clutch setup has to be removed and if so, will I need special pullers to remove the pulleys?
Old Mar 22, 2001 | 11:30 PM
SteveXplor's Avatar
Yes you have to take off the clutchs along with the backplate(behind the clutchs).Then you will be able to unscrew the nut holding the bolt.I bought a bolt that screws in the front clutch, then cut the head off a smaller bolt that fits in the hole.Put the smaller one in the hole then tighten the other bolt,tapping on the bolt with a hammer a couple of times and it should pop out.On the older models that have not had the clutches taking off,it might be harder.Hope this helps.
Nondem
Feb 22, 2020 12:20 PM
toonces
Jul 28, 2015 01:58 PM
Jul 28, 2015 12:12 PM
Bell21
Jul 28, 2015 06:52 AM
mdrkcckv
Jul 22, 2015 09:10 AM
